On Kohler K series engines, how important is the rubber boot that goes from the cooling shroud to the back of the air cleaner?
GANG GREEN GIZMOW KILLER!
Its there to give cleaner air to the air filter basically. The fan screen sorts out the big light stuff (grass/leaves) then the fan sorts out the heavier stuff (sand/grit) then the carb sucks in this pre cleaned air.
Youll be OK without it, better with it.:trink40:
