Test the compression and give us a number, a compression tester will be as cheap as a new head gasket, but you will be able to use the compression tester again in the future.
Dan
Dan
Providing that the engine was never replaced, a Kawi FB460V in a John Deere 160 IS A FLATHEAD ENGINE, NOT OHV.These newer overhead valve engines aren't anywhere near as forgiving as the old "flatties" that you may have been used to.
