21 - 25 of 25 Posts
Daryl G
Dual wheels changes it's personality dramatically, and makes it a real working tractor. More traction, more weight, and a wider stance. Dual wheels are worth every penny it takes to convert it.
Lnk,
Let me echo what franklin2 stated... dual wheels are absolutely incredible!!! I brush cut some very steep and sandy banks by our creek. Previously, I did this with just a pair of ag tires and it worked ME really hard because I was having to use a lot of 'body english' to keep the machine on track PLUS there were many sections that I simply could not access. Then, I picked up my fourth machine and as part of the package it came with a set of dual wheels. Some time passed and after reading on mytractorforum about the benefits of the dual wheels, I pulled these from my shed and installed the set. I have not removed them since that day! The improvement FAR exceeded whatever I could have imagined. The tractor's ability to perform on hills and banks has improved tremendously. The stability is... well, the machine is going where you point it. I can cut many more areas than I was I simply could not safely reach before. The only downside that I have experienced is that if you are cutting near trees, one needs to be very careful because more than once the extra stanch can grab a hold of a tree and swing the operator and machine as the Gravely tries to climb the tree.
I'll join the throng. Duals are great for marginal traction situations, hills or other rough ground. When I was using my first L8 as the primary mowing machine, I ended up with wanting them due to the ups and downs in my lawn.
https://www.mytractorforum.com/798159-post2.html
They *do* make it noticably harder to turn tightly. You get to practice your technique of not trying to muscle the tractor around :)
Discussion Starter #23
Sound like. Need to find a set of duals. At least for the C8, still not sure what the L is going to best used for. Will wait until I run her a bit to see what speeds I am dealing with. I do have an older brunch mower, with the two holes in the cap. Locked up right now but I will tear it down and see what it needs. It is an old 4 bolt, and is stamped 102 on the casting. I just know it is not a 106. Perhaps it can be my fence line mower.
I for one would like to see a dual wheel LS w/ GRW too! Would go anywhere.
I've never seen dual adapters for GRWs. It sure would be a beast!
I have run GRWs on one of my LS's. Talk about a crawler! It turns out that an LS with GRWs in low speed is just about exactly the same speed as a mountaineer in low/low/low :)
I keep meaning to mount a set of extension axles, and put GRWs on the ends. That would be nearly as cool as dual GRWs . . .
21 - 25 of 25 Posts
