1 - 15 of 15 Posts
Hi Guys
I just picked up a Sherman Power Digger Model 49. From what I can tell this backhoe was not very popular. I have searched the web and finally found something google can't find. I found a lot on the model 54 but zip for the model 49.
From what I can tell the big difference is the 54 has a cylinder on the bucket to curl where the 49 is fixed to the boom. The 49 only has 3 controls on the hyd quadrent - right left swing, boom up/down, and crowd.
Does anyone have one of these or has anyone seen one ?
Thanks
George
There's a couple machines here in town with backhoe's,a little similar to that.Where in CT are you?
Thanks for the link Kirk. I already have the original manual (from 1950) but the only picture in is the one above. I was surprised the parts list in the back or the manual didn't have any exploded drawings of the assemblies. From the one pic I have I can figure out how everything goes together I'm just not sure how it mounts to the tractor.
George
I'
ve got one on my 8N. Let me know if I can be of help.
Discussion Starter #9
Hi merlynr
If you could take a picture of how the hoe mounts to the tractor and a picture of how the hyd hoses are routed that would be awesome.
Thanks in advance for your help.
George
I can see it working for general excavating , digging a ditch etc. but not being able to load a truck as it would dump its load if raised to the height needed to clear the side of the dump body. Likely that why it wasn't very popular , true it was a cheaper system to build but limited use.
Discussion Starter #11
I agree it will be limited but will be handy to have on the property for general digging. I suppose I could add a cylinder to the bucket without to much trouble but I like the simplicity.
Hi merlynr
George
Are you only interested in the backhoe part or all? May be a couple of days. Ok only the hoe part, but bear in mind that all hydraulics run off of a pump in front of engine. It has pipes and hoses all over the place.
Discussion Starter #13
Actually if you could just get me pics of how it attaches to the back of the tractor that would be a huge help. From what I can tell there are suppose to be U bolts that go around the rear axle and brackets that mount to the center axle housing one on each side just below the top link.
Thanks
George
1 - 15 of 15 Posts
