should we sharpen this?
told it is stainless steel
I seriously doubt that. Basic identification is easy. Steel is magnetic, zinc test is easy, etc, but there are many types of steel and lots of different grades and alloys. Without specialized analytical equipment there is no way you can tell the difference between say 1095 carbon steel and 1050 carbon steel, or ATS 34 and any of the 440 grades of stainless steel. The minor differences in the composition make a big difference in how the steel performs.we absolutely guarantee that if
we ever want to know what kind of
metal it is
that machine shop can figure it out
If the guy told you that the engraving would be damaged if he tried to sharpen it that tells it all. He doesn't have a clue how to put an edge on a blade other than to put it on the wheel. Thats the only way that the engraving would be damaged. You just don't use power equipment to do that sort of thing unless you don't know what you are doing. If by chance the sword is made of some sort of decent steel, using any sort of power equipment to put an edge on it will ruin the temper, and once that happens the blade is damaged beyond repair. Any machinist that knows what he is doing would have told you that.how you can come up with an opinion
about them from a simple question like
that is beyond us
