1 - 2 of 2 Posts
I am having trouble setting my cruise on my B7510, I push down on the lever when I reach the speed I want to set it at, but the lever just comes right back up. Any hints on what I am doing wrong, or a way to fix what is going wrong? Thanks
Machinery enthusiast
The cruise control on these tractors can get a little complicated. They are designed to trip off should "both" brake pedals get depressed (linked together) or when the HST pedal is depressed. It's not supposed to trip off should the link on the brake pedals be flipped off and the pedals operated independantly (brake steeering).
1st thing I'd check is to make sure all the linkages are connected from the lever down to the brake and HST pedal linkages. Could be one end has popped off. You may need to crawl under it and have someone work the pedals and lever to make sure they're moving.
My BX23 didn't come w/cruise so I can't compare the operation.
Good luck.
1 - 2 of 2 Posts
