Same condition here..
I believe it is the concrete heating that turns the grass brown..
Its not the septic field, its brown over the concrete tanks..
That has to be some miserable heat!Its not the septic field, its brown over the concrete tanks..
:ditto: :ditto: only about 6 inches..During extreme dry conditions the grass will dry out faster over the tank, because there is less soil to hold the moisture.
That sure makes sense to me SlipDuring extreme dry conditions the grass will dry out faster over the tank, because there is less soil to hold the moisture.
Really? Our septics here are much deeper than that. Our home is 22 years old and the tank is ~ 36" down. No wonder we don't get this condition even in the dog days of August.:ditto: :ditto: only about 6 inches..
The lid or top of the tank is 6 inches..Yes, other areas are a lot deeper..Really? Our septics here are much deeper than that. Our home is 22 years old and the tank is ~ 36" down. No wonder we don't get this condition even in the dog days of August.![]()
You should really cover them up and plant some grass Ken ,, it looks like crap that way :trink39:My tanks
:ROF :ROF :ROFYou should really cover them up and plant some grass Ken ,, it looks like crap that way :trink39:
:fing20: I knew I forgot somptin...But this way no brown grass!!You should really cover them up and plant some grass Ken ,, it looks like crap that way :trink39:
If it is a gravity system the tank is set to catch a pitch to the leach field. Freezing the tank is not a problem if the tank is biodegrading the way it is supposed to. I live in the northeast and the tank at my flat farm is even with the ground and it has no issues.Depending upon the frost line and whether you have a basement, the tanks can be quite deep.
Now the hazard for us here in VA is that the collar going down to the tank will fill up with water during a heavy rain and can cause backflow problems in the basement.
