I am adding a selector valve to my 220. I added a second cylinder to raise/lower the rear sleeve hitch so now I need to tie it in. I modeled it after the cub cadet style of sleeve hitch lift. Not the pretiest out there but it will work good for what I need. I did loose the ability of the center pin hole on the hitch but I don't have any attatchments that require that pin hole any ways. I then mounted the selector valve on the right hand side of the pedestal figuring that was as good a spot as any. I hope to be able to snake the hydraulic hoses down inbetween the engine and pedestal. The valve was a bit larger than I needed but it was one I had on hand, as well as the rest of the fittings and adapters that are on it and the cylinder so I can't complain. I was hoping I had some fittings on hand to match the case but I do not. I need to know what size the fitting is coming off of the implement lift on the TCV so that I can buy a T and and an adapter to make it to NPT.
