1 - 8 of 8 Posts
I can let my tractor run at all different throttle levels and nothing happens. But as soon as I try and drive around the yard the tractor will die and won't start back up for a little bit. Then I let the tractor run for a while and it will do the same thing again, runs fine at a stationary postion at all different throttle levels but as soon as I take off the tractor will die again.
I am think the problem is the float.
You might try looking at coil/electrical problem rather than carb problems. Maybe a loose wire when the unit moves?
I ordered the brass float from that site already. i am just waiting for it to arrive so i can put the float in.
Deere 330 Killer
Gotcha, while your at it, check your throttle linkage
Deere 330 Killer
when you move the throttle lever up and down, check to see whats moving and what, if anything isnt. I can post some pictures tomorrow. Just make sure the cable on the throttle butterfly on the carb is moving
Discussion Starter #8 (Edited)
Yes, the butterfly is moving I checked that already.
What about the gas cap vent?
1 - 8 of 8 Posts
