I bought a couple of Sears plows a couple of weeks ago for a good price knowing I'd have to adapt them to my Cat 0 3-pt hitch or pull them another way. After my dog failed to be an alternate pull source I figured I'd better fab something up
Fabbed a couple of adapters yesterday. The hardest part was drilling 1/2" pipe out to 5/8"ID so if you have a source for 5/8" ID pipe I'd go that way. All it took was a couple of pieces of 3.75" long 5/8" ID pipe and 2 Cat 0 pins and I had some adapters. I cut the ends off the pins and plug welded them inside the pipe then drilled the pipe so they could pin on the plows without having to permanently modify them.
