When rebuilding carbs, sometimes it is necessary to remove the brass or aluminum welch plugs from the carb body to do a proper cleaning job and sometimes they just come loose.
When replacing these plugs (also look like frost plugs in the block of your car engine but much smaller) it is recommended to use some sealant between the plug body and plug. What is the best sealant to use? In the old days I used to use nail polish as gasoline would not dissolve it. I have also heard that some people use epoxy.
Any recommendations? Thanks
