Update...
I actually finished this project a few months ago and took a lot more pics but forgot to come back and post them. I was reminded when another member asked if I had ever finished... so here they are. I've been using this cab several times with my snowblower and it's great staying out of the blowback.
These pics are primarily of fitting the cab frame (yet another attachment that wasn't designed for my model) up to the tractor, and of polishing the thin lexan windows of the cab to remove/reduce scratches (using Meguiar's PlastX.. links below).
I also gave the softside material (stoprip vinyl) a once-over with fluid film inside and out to help keep it supple. It also gave it that armor-all sheen for a few days until it was fully absorbed (or evaporated, not sure which).
As a reminder, here was the starting point, as garbage picked:
The business end of the cab.. front hardware which attaches at (sort of) the footrest. Cab is upside-down in this pic.
Same upside-down shot but of the rear attachment hardware (which didn't reach the rear of my tractor.. I had to extend the frame.. more on that later.
Used my overhead winch-as-hoist to suspend the cab frame over the tractor to make it easier to line it up and work with it. Was handy not having to fight gravity.
Used some chain and a threaded link at the four corners of the cap frame to keep it roughly level while hoisted.
Here's where the cab hardware landed at the left footrest. Didn't exactly line up to anything convenient to attach to. Plus I didn't want to lose the footrest rubber gripper pad. Pics toward the end of this series will show how I bent the cab frame to fit up and where I bolted it on.
Parts of the cab frame were pretty rusty but I didn't take the time to clean them up and paint them. I just wanted to get it installed for now, and will go back (maybe in spring) and do all the cleanup and give it a fresh coat of paint.
Pretty much same deal with the right footrest cab frame attachment. Nothing lined up so mods were needed (more later):
I was worried there wouldn't be enough clearance between the steering wheel and the front of the cab for my fingers on the wheel and fist when using the spinner knob. Turned out ok.. there was about 2 1/2 inches of clearance.
Here's the rear of the frame. Kind of came up short.. didn't quite reach the tractor. Well, some of the bracket parts did, but not enough to provide sufficient support.. the whole cab would easily squat down with a little weight. I needed to extend the two main rear cab frame members.. more on this below.
One of the rear support braces was missing (the cab was garbage picked so I can't complain). So I fabbed one up from 3/4" flat steel stock.
I had to cut out some of the left (and right) footrest so the cab's lower bracket would fit.
Here's with the lower bracket in place. Picture out of focus.. camera decided to focus on the body of the tractor behind the frame instead...
Time to put the tractor up on dollies so I could easily move it around, changing it's position under the overhead hoist to cause the cab to lean one way or the other to assist with lining up various parts of the cab frame to the tractor. This is the box for the
car dollies I bought at Tractor Supply Co.
The dolly (one of four.. came two to a box).
Here's the tractor up on the dollies. Used the ceiling hoist to get the front wheels up on the dollies and used a hydraulic car jack for the rears.
Here's the rear cab frame tubing where I needed to extend it. At the joint near the tape measure the vertical tube ends and connects to a horizontal tube (going off to the right in the photo) and a flat bracket going down diagonally which I assume was not intended to support weight, just to stabilize. So I needed to extend the vertical frame member straight down. It's 3/4" OD tube that widens to about 1" where flattened at it's end. This fit perfectly in 1" square tubing, so that's what I used.
This shot shows the square tubing installed (and painted). I also added the horizontal member (angle iron) that the square tubing is attached to at the bottom. What I hadn't done yet in the photo (and still haven't done yet) is drill a hole through both the square tubing and the round tubing inside it and install a bolt to fix the two together. Right now without the bolt it kind of acts like two gas shocks and it's fairly stiff so I left it for now.
Another shot from the right side looking back.
And from a little higher angle. That silver metal piece on the right side of the photo is the brace that I fabbed up shown in an earlier pic in the vise.
Cab frame fully fitted up to the tractor here, minus the cap. I'll have some closeups of the interior attachment points further down this posting...
At this point I removed all the softside material (ripstop vinyl with thin flexible lexan windows) and took them outside for a good washing down in preparation to buff out the scratches in the windows.
Here's my high-tech washing station.. old door on sawhorses, mild soap and water, paper towels.
I wanted to put something dark colored (but soft) underneath the windows when I was cleaning and polishing them so the dirt and scratches could be more easily seen. So I used the inside of my beater shop jacket.. worked pretty well, just wasn't big enough to fill the entire window so there was some moving around required.
I bought
Meguiar's headlight restoration kit with included PlastX polishing creme (right) and an
extra bottle of PlastX (left) just in case.
The headlight restoration kit included a 6 fl oz bottle of PlastX and the entire job all windows (inside and out) ended up using about 4 oz of the polish so I never tapped into the extra bottle I bought. But I figure I'll have other uses for this stuff. It did a pretty good job as you'll see in some of the upcoming photos.
Here's what comes in the restoration kit (drill not included)
Here's the recommended application amount of the polish.. about the size of a nickel. The area you can polish with this amount gets bigger as you go because in the beginning it gets absorbed into the polishing brush but later pretty much all of it ends up on the work. Later on when the brush is pretty loaded up a dollop of this size will cover maybe a 10" by 10" area.
You're supposed to hold the head at an angle when applying... not straight down at 90 degrees, and not horizontal so you're using the edge of the head.. more like a 45.
Here's a shot showing what the polished area looks like compared to unpolished. The polished area is about the upper 1/4 of the window in view in this picture. The part where you see the reflection looking "smeared" is just where it goes over an uneven surface (my jacket beneath it). However it is possible to heat warp the lexan if you polish too agressively. That's something to watch out for. Just take it easy in the begginning and stop and check the warmth by feel periodically until you get a sense for how much speed, pressure and time you can use without overheading the work.
As the job progressed I figured out that it was quicker to pre-apply some dollops (and smaller than a nickel in this case) directly to the window instead of to the polishing head on the drill.
Here's the dull haze you get after polishing with the brush and before removing/buffing with the included chamois.
As I lost the light I had to move indoors...
Here's another shot showing the difference between polished and unpolished.. the little arced area in the corner where the head couldn't reach is the unpolished part.
Same corner viewed from inside the cab.. shows the difference more dramatically as you'd experience if you were in the cab with sunlight shining directly on the window.
Here's a shot of the rear window after polishing
Another closer shot of the rear window after polishing
Here's a sort of before polishing and after polishing comparison of the rear window. Lighting and angle weren't exactly the same so this is a little subjective but the difference was definitely noticeable so the effort was worth it in my opinion.
Then i started on the windshield. It had lots of overall scratches, plus some pretty nasty diagonal abraided areas where part of the front frame would rub on the windshield (I think the PO installed them backwards... I reversed them and this provided more clearance). This is the before shot.
Here's the after shot.
After all windows polished and the softsides back on the cab.
Here's an interior shot, left footrest area showing the little "tire view" window that was also polished.
Here's a before and after comparison of the left footrest area. In this shot you can see how I discarded the bottom angle iron part of the cab frame and put a pretty serious bend in the narrower vertical member, plus where I bolted them to the tractor. Seems with all these mismatched attachments I get I'm always drilling more holes in the tractor or cutting this or that.
Interior shot, right footrest, after clean and polish.
Another before and after comparison, right footrest area. Again, I discarded the angle iron and had to put a few bends in the frame pieces to provide hood relief and get the bolt holes at the ends of the frame members to end up where I wanted them for attachment points.
Interior shot, operator position.
After all the cleaning and polishing I also coated both the inside and the outside of all the ripstop vinyl with
Fluid Film. Worked good, but man, that stuff smells nasty for a while until it fades.
Also note the extreme air gap between the cab side doors and the tractor fenders. No worries about CO poisoning in this cab.. plenty of air flow. Nonetheless i do carry this
portable CO detector in the cab when I run the tractor.. and so far have not had an alarm.
Another angle, post-fluid film. I put the cab's cap on later.
And here's a recent shot of the cab serving it's intended purpose! (cap visible in this one.. wouldn't do much good in the snow without it)
