I had the BH and FEL removed from the tractor for about a month. During that time it has warmed up quite a bit. This put a hydraulic lock on my quick disconnects and I couldn't get the lines hooked back up because of it.
I finally figured out that the center tip needed to be depressed to depressurize the lines in the implement so they could be hooked up. I needed to hook up the BH first and during that month the stabilization feet cylinders had bleed down and it was a major pain getting the hydraulics hooked up first, then raising the BH and aligning it to the mounts on the tractor
But, as they say alls well that ends well.
