SB800 how loud is the chain?
1114 Views 2 Replies 2 Participants Last post by  black88mx6
Started up my SB800 for the first time. It is spinning and seems to be working well. Wanted to know how much noise the chain and blower makes. I have no idea how loud this is supposed to be. I would suppose the chain could make some noise. Just wanted to make sure the bearings are good. They all spun smoothly.
Also at first the unit was bobbing up and down, but then I rotated one of the augers so that they are opposite each other and it smoothed it out.
1 - 3 of 3 Posts
Motorcycle chain lube makes the chain run quietly on my blower. The only noise I hear is the second stage rotor scraping slightly. It has been that way for years so it must be OK.
It is possible that it's my second stage rotor. It's not screeching or anything. I purchased chainsaw gear lube for the chain. Will test some more. Lots of rotating parts, and I am sure it's not supposed to be silent or anything. I can rotate everything smoothly by hand. I have to check to make sure that the chain has 1/4 in deflection, as stated in the manual.
Thanks for the reply. Maybe I will post some video. ;)
1 - 3 of 3 Posts
