1 - 3 of 3 Posts
My Super 2 is a 16", and measures 16 inches even from front edge of engine cover to tip of bar, including the blade tooth.
Proud Member of the 1K Club
I have a Homelite Super 2. It's either a 16" or a 18" How do I measure the bar?
standard size for them are a 16" another way to tell is how many drive links are on the current chain but that is a time consuming task itself
but like ured said measure from the tip of the end to the sprocket area where it mounts up at
another thing there should be some numbers or letters engraved into the metal part of the bar check for this to see if it is there i can cross reference them numbers to the part # of the bar
there should be a UT # on that saw i need to make sure of the part # of the bar by that ut # check to see if there is a number stamped into the metal of the bar it will be located towards the case cover side of the bar where the clutch is
if there is any numbers on there
calvin
1 - 3 of 3 Posts
