Two (2) Months I bought a Ryobi 48110 Electric Tractor at Home Depot in Spring Hill, FL with the following problems listed below:
The grass is always unevenly cut, for example, high and low areas and a lot of tire tracks.
Grass discharged leveler keeps moving out of place when I hit a small bump or get off the tractor; it will catch onto my clothes disengaging to a lower level cut.
One Item in changing the blade the torque is 600 to 650. My torque wrench only goes up to 200. Called Ryobi and they could not tell me if this is pounds or mm to calculate the right amount of torque for installing the new blades.
The Ryobi 48110 Manual is useless, it does not explain the proper way to level the deck. YOU Will NEED TO BE A MECHANIC TO UNDERSTAND/DETERMINE HOW TO PROPERLY LEVEL THE DISCHARGE DECK.
Home Depot does not sell parts or blades if you need them; you will need to order them on LINE. The question I asked the manager Why would you sell the Ryobi Electric Tractor. If I was made aware of this I would have never bought it.
JUST BEWARE: The warranty starts on the date you purchased the tractor; not the date of delivery or accepting the tractor. It took approximately 2 additional weeks prior to me receiving my order. This was not fair as the delay in delivery was Home Depot fought in Spring Hill, FL. So my warranty should have started on the date of Delivery (when I accepted the Tractor).
NOTE: If I had known the items I have listed, I would have never bought this Ryobi 48110 Electric Tractor at Home Depot.
