Ryan weed trimmer fuel ratio?
222 Views 10 Replies 3 Participants Last post by  Snoopy11
I was wondering if anyone knew the fuel to oil ratio for a Ryan model 263 weed trimmer.? I did some research, but found nothing specific to Ryan.
Also, what oil are you supposed to run in them with the gas? The label says to dump a full can of Lawn-Boy special lubricants oil in with 2 gallons of gas. Ryan oil is now discontinued obviously. I would assume that I’m supposed to use modern Lawn-Boy oil as pictured below.?
Liquid Fluid Gas Rectangle Wood stain
1 - 11 of 11 Posts
Can you go by the amount of oil?
Posting this here... hoping it is relevant:
2.6 oz of oil added to 1 gallon of gas makes 50:1
5.2 oz of oil added to 1 gallon of gas makes 25:1
3.2 oz of oil added to 1 gallon makes 40:1
4 oz of oil added to 1 gallon makes 32:1
I don't want to start another oil argument... but Klotz is literally the best for 2 stroke engines.
Don
I have those amounts on the bottle of oil. I just don’t know which of those ratios that Ryan/Lawn-Boy/OMC weed trimmers take…
Ok, thank you. I really appreciate it. If you don’t mind me asking, how do you know?
Tin Tin can Automotive tire Aluminum can Tire
Tin Drinkware Paint Aluminum can Drink
4oz of Ryan oil to 1 Gal...
5.2 oz of "other oil" to 1 gal.
You aren't going to go wrong by using 25:1...
Maybe this is a dumb question, but why 5.2 oz of any other oil(such as modern Lawn-Boy) if not Ryan which is 4 oz? Wouldn’t it be the same 4 oz of oil regardless of brand getting me a 32:1 ratio?
Well, that is what the old manual indicates... I am thinking that maybe the Ryan oil is a castor mix...
Don
Don
Oh, ok. I suppose I will use 5.2 oz of modern Lawn-Boy oil with a gallon of premium gasoline at 25:1. Thank you for your help!
I've been running shell nautilus 2 stroke syn. in my echo saws and trimmers for 10yrs because I have a huge supply of it! and there still working great! 1 jug will last you a lifetime in a trimmer!
klotz is great in a sled when your driving away from it but a trimmer, who needs to stand in that stink!
Hey now! I like the stench...😆
Don
1 - 11 of 11 Posts
