First questions from new member and soon to be John Deere owner (yes, my first)
As I noted in my intro, I will be taking delivery of my x748 in a couple of weeks. Primary use will be mowing around the homestead and tilling garden areas. However, I have a couple of pastures that I have mowed a couple of times a year – they are pretty flat and primarily high grass. Problem is that the rocks seem to flourish between mowings and I don’t want to bang up the 7 Iron deck. So, I want to get a shredder to mow these pastures. I have seen videos of the x748 with a JD 403 and maybe a 413 and a few other similar sized GTs with LX4 and even some 5 ft mowers. My question is what should I be looking for with this machine? I will have the front heavy weight bracket so I can put up to 9 suitcase wts for ballast. What is the weight limit on the rear 3 pt? I have read some about the JD Implement Codes – does JD establish a code for their GT’s?
I am not too worried about lift height given the layout of the land and such. Can this machine handle a JD LX5? I see a lot of 5 ft mowers around, not so many 4 ft.
When I bought the machine I asked the dealer about the Frontier 4 ft mowers and he simply replied “not listed as compatible so I can’t sell it as part of the package”. He did not say the machine could not handle it or make any other suggestions – maybe legal disclaimer concerns we see all the time these days. But I know a lot of folks successfully run shredders on this type of machine, especially with the diesel torque.
Thanks for your input – I will probably have more questions as the info pours in!
