Blasting wheels with tires mounted isn't uncommon; the blasting shouldn't do any harm to the tires; if you're concerned about it, you could put some duct tape on the tire around the rim; either way, it's not like you're focusing the blasting on the tire so it should be fine. :fing32:
Wont hurt the tires, might want to let the air out of the tubes and push the valve stems in though and then stick a plug in the holes while you're blasting. The valve stems, unless they are metal, could heat up during blasting and fail.
darn valve stems r hard to fish back outta tire after ya push them in...if I use 'gator tape' on the stem...I may get by that way...leave air in tires too..
The valve stems don't heat up any more than the tires do. I've had rims shotblasted in a Wheelabrator and forgot the odd valve stem. No damage to the stem and steel shot is a lot harder than sand. Just make sure the caps are on the valve stems.
A forum community dedicated to all Tractor owners and enthusiasts. Come join the discussion about specifications, modifications, troubleshooting, maintenance, and more!
