1 - 7 of 7 Posts
I've got a portable generator that I use for emergency power. I curious about switching from gas to run on propane because of fuel stability of gasoline. Anybody have first hand knowledge on the pros and cons of doing this?
thanks, Dave
Administrator - We’re all friends here
I have considered changing over to NG. My gas pipe runs about 8 feet from where I place the generator, so that part is no problem. The carburetor has to be partially disassembled, some parts changed and some passages drilled out. I don't think I use it enough to justify the project. I just burn out the gas and/or add fresh gas every time I test run it. Here's a link explaining how to change the carb over to gas:
http://www.propane-generators.com/carb-conversion.htm
Yep, been doing some digging around a found that site as well as some others.
There is another method that I'm going to use, still allows gasoline to be used. A conversion kit is available that uses a sleeve that mounts between the air filter and the carb. The kit doesn't require mods to the carb except drilling a hole in it and inserting a vacuum port, this attaches to a emergency cut off should the engine die. The sleeve extends the air filter out about 1 1/2 in. so some frames need to be modified, my doesn't from the looks of things.
http://www.propane-conversions.com/generators/
These are the only folks I've found that actually answer the phone or return phone calls. :banghead3
That kit looks like the better choice. You wouldn't have to do too much modification of the carb. :fing32:
I'm about to place a order, I'll post some info as I go through the process. I'm a bit surprised about vendors and websites out there that sell the stuff. I found 4 on the net, of them only one answered the phone...no body else even returned my phone calls.
1 - 7 of 7 Posts
