I have been reading a lot of the threads on hard cabs, and I have a idea that might help when fitting a cab.
I'm talking about the front end of the cab and how to seal that up.
Looking at this picture.
On the drivers side door post near the area where the bottom of the windshield is, about that height put a hinge, then go down a ways and put another hinge.
Then you make your front cover to fit then add the hinges.
In this picture.
The rubber that goes around the windshield is pretty good sized and you could take something like that and put in along the edge of your front piece that rests against the hood.
Also the hinges I mentioned you could get the type that you can remove the pins, this might make it easier for fitment or as a end result also.
In this picture.
