Welcome to the forum Josh.
For the steering, try to get grease in all the movable points and the gears. If that is not possible, at least oil them. Weight in the rear will help a little with the steering. I put these thrust bearings on all my machines and it helps a lot. McMaster-Carr 5909K33 and two 5909K46. Or here. Thrust Needle Roller Bearing 3 4"x 1 1 4"x 9 64" inch Thrust Bearings 0 750 Bore | eBay They fit on the bottom of the kingpin. Make sure it is 3/4".
You will need tire chains and weights to use the blower effectively. If your drive is hilly, it will be very difficult to use without them. Mine will not back up on even a slight incline when the blower is lifted, without weights and chains.
Without the belt idler, the belt will most likely slip when under any kind of load. It looks like there are two different setups for that idler.
I have an asphalt drive and it does get scratched and marked up but mostly from the tire chains. The blower skids ride mostly on the snow layer. I have tubes in all my tires for the same reason you speak of and chains work fine on them.
