Fill them with fluid, no more leaks...:thumbup:my 318 came with the wheels reversed. Hint:
GET LONGER VALVE STEMS for the tires. mine are a PITA to fill up...might help though if i fixed the leaks![]()
Yes they are,just unbolt them,turn them around and bolt them back on.I run them in the wide position on my 345 because I mow some side hill and it gives a wider stance.If you have ag-lug tires you can still switch them over to wide but you need to also switch them side to side on the tractor because of the directional tread.With some mowers you also need to do a slight change to the left rear guage wheel and the manual gives good detail on that,either way its not a big hassle.I have a X585 and want the rear wheels wider for mowing my ditch.
Are the rear wheels reversable?
Thanks brother! I'll give it a try.:thThumbsUYes they are,just unbolt them,turn them around and bolt them back on.I run them in the wide position on my 345 because I mow some side hill and it gives a wider stance.If you have ag-lug tires you can still switch them over to wide but you need to also switch them side to side on the tractor because of the directional tread.With some mowers you also need to do a slight change to the left rear guage wheel and the manual gives good detail on that,either way its not a big hassle.
Would you mind posting before and after photos as viewed from the rear of the tractor? I'd like to see what the difference is.Thanks brother! I'll give it a try.:thThumbsU
I look at the rear wheels on my X720, and I can't figure out how flipping them would make a wider stance? :dunno:
So you take the wheel off, rotate it 180 degrees, and stick it back on the same side? The wheel looks deep dished to me, and flipping it looks like it would make the stance narrower? What am I missing here?:dunno:
Yes you can reverse the wheel and gain an inch of width. I know it doesn't sound like much but looks like more than an inch.:fing32:Interesting, didn't know this was a thing. Is this do-able on the 455? Any extra stability I can get with my hills is a plus.
