1 - 2 of 2 Posts
I have repowered my 1220 with a chiwan knockoff of a honda gx390. The orginal ampmeter has died. I have a new SW (same a the orginal) and in checking the wiring it appears to to be wired wrong so I am trying to correct it. Any hints as to how to wire the amp meter into the clone wiring circuits?
Thanks for your help.
There should be a smaller wire attached to the same post that the heavy, battery positive cable is attached to. That wire would be disconnected, attached to the ammeter, and then a new wire from the other post on the ammeter would connect to the original connection point.
1 - 2 of 2 Posts
