1 - 16 of 16 Posts
· Shop = My Therapy
Put as Kohler back in. Might be easier. But a deisel would be great.
· Has anyone seen ChimChim?
Nothing is impossible it just takes time, patience and careful planning.
For sure! Lots of pics :)
Hi Mike, I believe that the L series tractors are all vertical shaft engines and you need a horizontal shaft engine for you 317. The Kohler Command engine is a good choice for repower; you could also consider a Briggs Vanguard. Good luck.:MTF_wel:
· Penn State Puller!
I know this thread is 3 years old but for anyone else interested, I would recommend this...it's a Lombardini twin cylinder diesel made by Kohler. Looks like it would be a good fit for a 317 assuming it uses the same mounting points and everything.
http://www.lombardinigroup.it/products/diesel/ldw502
Buy a 332 and be done with it. Modifications to fit a radiator would be a challenge.
Lombardini makes diesels and puts the Kohler brand on them in the USA. They also make air cooled diesels in the 12- 27 hp range.. It would be interesting to see one of those swapped into a small tractor.
The only thing I know is that they are expensive.
The only multi cylinder air cooled diesel I have any experience with was extremely loud. That may have changed, I don't know
Digging up an old thread. :sidelaugh
It can be done, but it is a LOT of work.
1 - 16 of 16 Posts
