Hi everyone, i want to replace an old ignition coil with a new electric ignition coil (398811) on my Briggs & Stratton engine (220707-0133).
Here you can see the old ignition coil:
https://www.directupload.net/file/d/5512/yjevzxjv_jpg.htm
And here you can see the new ignition coil:
https://www.directupload.net/file/d/5512/8iunnsx4_jpg.htm
I think I don't need the condenser anymore when using an electric ignition.
Can I just cut the wire between condensor and coil, remove the old coil and replace it with the new coil? What about the condensor and other parts? If I don't need it anymore I can remove it too?
Thanks for your answers :).
Leave the points and condenser in place, just cut the wire. If you remove the points you will need to plug the plunger hole
