Replacing hydraulic hose...what to use???
1859 Views 7 Replies 7 Participants Last post by  GrebesBakery
I'm am replacing the hydraulic hoses that come of the oil cooler, wondering what type of hose I should be using. I assume a radiator hose won't hold up...
1 - 8 of 8 Posts
I would be surprised if the oil going through the oil cooler was under high pressure, but someone correct me if I am wrong,, Even though, I would be tempted to have a hydro hose made up professionally just for safety and equipment sake.
d
No don't use radiator hose go to a hydraulic shop and buy hose used for oil as a return line.
Go to Northern right down the road. They have it
Spend the extra buck (or few) and get the good hose clamps while your at it.
http://www.tompkinsind.com/catalog/adapter.asp?cat30id=6621
d
Just for clarity, the pressure in the return system on these tractors will routinely run 200 PSI. A properly spec'd hydraulic return line hose stock will be rated to a min working pressure of 300 PSI.
This is not a 'high' pressure circuit which would require fabricated hoses.
Generally spec'd automotive heating/cooling hose will not hold up to hot oil flow ... often fail in a matter of hours.
Brian
1 - 8 of 8 Posts
