1 - 11 of 11 Posts
So I have two of the early 80's Craftsman II garden tractors.
One has no engine, one has the original Briggs and Stratton L-head engine.
I'm looking for a brand new engine to replace the original with. The trick is, I need it to have a PTO shaft on each end, so I can use my snowblower, and other front end attachments, in addition to powering the back wheels.
None of the harbor freight engines seem to do the trick. B&S has no suggestions.
Anyone have one?
From what I've seen online (as I haven't had to directly work on a engine like that myself), (almost?) nobody makes small engines like that, but rather, the manufacturer (B&S or Sears/whoever made the tractor), would make something that bolts/screws/connects to that side of the crankshaft, to extend it out then use that as a PTO shaft.
Hmm... I was already hoping to use the electric clutch on that side so....
...just to be clear, I was referring to the non-pto side of the engine, where they attach a shaft/pulley/whatever to the flywheel/end of the crankshaft/fan mounts, depending on what's convenient and how much power is needed.
I have one of those (GT6000) with an 18 HP Kohler horizontal shaft engine.
There is a bracket that bolts to the flywheel that has a shaft which sticks out for the electric clutch to mount on.
Power comes off the rear of the engine toward steering wheel that goes down across a set of pulleys that redirect the belt to the rear axle for motion.
PTO power comes off the front of the engine, flywheel side, down to a pair of pulleys that direct the belt back to the mower deck.
I can take a picture or two tomorrow if you want.
I would give you the engine model number, but unfortunately that tag is MIA.
Also I have a friend that has a bunch of Bolens tractors, that setup is on several of them.
Briggs and Kohler both offer stub shaft kits for applications such as yours, they are easy to install with the engine out.
I told you wrong, I blame CRS.
2492406
The flywheel is back toward the operator, and that side drives the rear axle.
Not sure if that adapter can be attached to a regular fly wheel or not, have not had that apart yet.
The clutch for the mower deck is right behind and below the headlights, I could not get a picture without some disassembly.
How did I do this, went from one post with a double picture to two posts with a single picture.
Moderator, please delete this post for me.
I don't know about a new engine. The old LT/YT Snappers had engines that might be compatible with your Craftsman. I still have the engine out of a YT16 that I scraped. See picture in post #2.
I see these for sale cheap on Craigslist and Facebook occasionally. The flywheel was set up to bolt the driveshaft to.
Cannon.
I was bored today.
Kohler front drive shaft or Kohler front drive adapter as a search term will bring up several different options from several places.
Then I started looking at flywheels.
Not all of the flywheels are drilled and tapped for the front drive adapter to bolt to.
1 - 11 of 11 Posts
