Nail in the tire what do you.
1 - 20 of 44 Posts
· Once again a Super Member
Another Wingnut Survey
· 20,000 +posts!
I "tube" lawn tractor tires usually,myself..
I must be doing something wrong, because when I try using plugs or "tiger tails" in lawn tractor tires it doesn't work 90% of the time,or the tire keeps "ripping" a bigger hole in itself every time I push the tool through with the plug on it (2 ply??)--I dont have any issues plugging car or truck tires.....anyway,I get most of my flats from dry rotted sidewalls than punctures..they should make tubless tire liners like they used to have for cars in the 60's for 12" tractor tires..if there were a way to seal up dry rot cracks I'd never have to buy a new tire,most of the ones that wont hold air now have excellent tread..and tubes cost a lot more than they used too!..
· Citizen of Earth
I am assuming that we are talking low speed off road tractor tires? I' plug, or patch if at all possible. I've had really good luck plugging nail holes in car tires as well.
· Landscaper
On my ride-on one of the tyres is tubed and the other 3 un-tubed....since squirting some 'puncture' free gel into them all, had no problems with either of them.
Though, as mentioned in a previous thread of mine...some people have had issues with this gel rusting the rims...
So tubed or un-tubed...not really fussed, long as the gel's in
Tubes all the way. I am not even waiting on my 2320 it has tubes in the rears because of the calcium but I am get the fronts done as well. Had too many flats on the turfs I had on one nameless LT and I don't waste my time anymore.
· AKA Moses Lawnagan
I voted on patching the tire from inside, but I'd have to say "it all depends".
If I hated the tires, looking for an excuse to get different ones, I'd say 'replace the tire' (and I'd probably be running over glass, nails and anything else I could find )
If they were brand new, and it was a tiny hole like a thorn would do, I'd use "Slime".
If they were worn a bit, but I couldn't quite afford new ones yet, then I'd patch, plug or tube them.
"Green slime" and fix-a-flat are two entirely different animals, and should have been considered such for the purpose of the poll. When I had my rental business I used tire sealant extensively, both as a repair and a preventive. Rims always looked like new inside. I would never consider using FAF- that's what gives you those nasty looking rims.
We're not talking high speed here gang... plug kit is the way to go.
Two minutes and you're on your way IF you have 4 ply tires.
Two ply tires are iffy for plugs and require internal patch or tube.
Regardless, NO SLIME or comparable mung. Lost a set of wheels to slime rot.
1 - 20 of 44 Posts
