I have a gas leak and need to get to or pull my gas tank.
whats the best way to do this?
is there a diagram with directions located anywhere?
thanks in advance guys,
Matt
Easy...
-Remove left & right cowl
-Remove brake, forward, reverse & diff-lock pedals
-Remove rubber floor guards
-Remove front (1 left, 1 right) & floor bolts (1 left, 1 right)
-Remove four seat screws (Torq fitting)
-Remove seat switch from bottom of seat and put seat aside
-Remove light harness' from rear lights
-Remove Fender Assembly
-Disconnect fuel level switch
-Disconnect fuel line
-Remove fuel tank
I can do this in under ten minutes...
Ready...Set....Go
