1 - 1 of 1 Posts
I got the bottom belt pulley off the drive shaft. But the PTO/clutch is a problem. Does it "pull off" the drive shaft, as well? I need to get to the two wires since they are broken. For some reason, the PTO engaged the whole mechanism and even the part that is kept from turning by the welded brackets started spinning around--perhaps a bearing issue. Thanks a million. Stacy
1 - 1 of 1 Posts
