21 - 30 of 30 Posts
The Sea of Green Machines
Many thanks for that Al!
Those keys are almost pressed in and very tight. They can be removed through tapping and prying with punches or chisels, but be careful as to not damage the shaft. I had to replace the key on the input shaft on the trans in my 10591 when I had it apart for servicing. I trashed it after having to remove it to replace the input shaft bearings which were worn.
If the keys are that hard to remove what does it take to put the new one in?
Discussion Starter #24
First, I used a file to smooth the edges of the key. (I had caused a few spurs on it from trying to use vise grips to pull it out.) Then, I just lined it back up with the slot in the crankshaft and used a large set of channel lock pliers to press it back into the slot.
I wonder if this procedure will apply to my 1984 Toro 20672 and other equivalent Toro mowers equipped with the BBC, such as the 20584, 20624, 20676 and 20684.
~Ben
Not too familar with BBC. I do have an M with bbc though. Its working fine now. If I have a problem in the future, is it possible to do away with the BBC all together?
LB-Keasler
I have just replaced both of these bearings in the BBC. Parts are readily available on Ebay using 6004 bearing for the upper and 6006 bearings on the clutch assembly.
https://www.ebay.com/itm/6006-RS-6006-2RS-Premium-Bearings-30-x-55-x-13-C-3-EMQ-Bearings-USBB-I-P/372018992048?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
https://www.ebay.com/itm/S6004-2RS-SS6004-RS-STAINLESS-STEEL-SEALED-BEARING-20x42x12-ABEC3-C3-I/231721476361?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
There are multiple brands available just go by the size if nothing else. I decided to buy these as they are American made bearings or so I think. The original bearings in my clutch were NSK bearings. As for the clutch disc it looks to be in very good usable condition.
21 - 30 of 30 Posts
