Hi, guys. We'll the old rear tires on my 1256 Hydro need replacement. I had a new tube put in one of them today. The brainiac inflated it to 30 PSI and set it outside the building to bake in the sun and 90* temps all afternoon. Center of the tread is now so bulged out the tire is at least 2" taller than the one on the other side. Whole tractor now sits noticably crooked. In other words, they're done. Internal structure of the tire must be breaking down, would be my guess.
So.... since I have to put snow chains on these things in the winter I'd like to get a tire that is as close to the original in every way as possible (the chains are tempramental to install, as I'm sure many of you are aware, even to small stuff like proper inflation pressure).
Tires are the original 1972-vintage Goodyear 2-ply rated 23 x 10.5 -12. Tread pattern appears as alternating rows of paralellograms. (I think they're called Terra Turf or something like that- didn't have my reading glasses on when I looked at them a few minutes ago).
Best suggestions?
Thanks in advance, guys.
Best suggestions?
