Hey got on my ST/10 to put it back in the garage and wouldn't go anywhere, put it in gear and nothing, but was able to push it in the garage (while in gear) lifted it off the ground checked belts, pulleys, etc, everything seemed good, and in place, also while off the ground and in gear was able to turn the rear tires.. missing anything? or is there a certain trick to tell if clutch or rearend is bad? Thanks.
