Rear Push Blade for a 316
3190 Views 17 Replies 9 Participants Last post by  red454
I have an old blade from a 1974 Sears tractor - several years ago I made a mount so I could use it with the manual 3 point hitch on my '67 Sears.
Now that I have a 316, I am going to use it on that tractor, so I made some collars to attach the center lift bar and a lower mount so the blade can pivot up and down.
This is a test fit for now - there is still work to do...
1 - 18 of 18 Posts
Looks good, nice job....
Thanks-
I ended up using some garage door parts for the final assembly. The angle arm and the long connecting bar (with holes) are from a garage door - (the parts that connect the trolley to the garage door). The seem to work rather well.
Tested it pushing some dirt. Works well.
Now I need to clean and paint it and I will be ready for winter...
http://picasaweb.google.com/redLS5454/RearPushBlade#
loos good , well thought out and best of all CHEAP
shd
Looks nice. Clean 316 too :thThumbsU
Cleaned the blade and mounting hardware up and repainted - here are some before / after pics. Adjusted the lift so it raises 6 - 7 inches now. Ready for some snow.
Well, now that it's green and yellow I can comment on it! :biglaugh: :biglaugh:
Nice blade, great buiid on the bracket!
Great idea red454 :thThumbsU
Now you have me thinkin again :fing20:
Thanks -
I was wanting to mount it in front, but since I already had mounted it to the rear of my old Sears tractor, it was fairly easy to make it work on the JD.
I am not sure how well it will work with the turf tires and no chains. The first snow should be a good indicator.
The other concern was how well it will start when it is really cold out. It was close to 30 degrees when I started it today and it fired up after only a few seconds of cranking. And that is one reason I did not get a blower for this year. I would hate to drop $300 on a snow blower, spend the time cleaning it up, and then when it is good and cold, I can't get the tractor started. So if it works well this winter, I may look for a blower next year.
-Chris
Very nice work do you have any type of skid shoes for it? You may need to find some or have them fabed up for you. Just thinking out loud here when backing up without the skid shoes you may find that the blade will want to dig in and stop you from reversing. slkpk
The bottom edge of the blade has an angled piece bolted to it - so there is roughly an inch wide "bar" of flat surface for the blade to ride on. It worked fine on my other tractor. The trick is to mount it so that when the blade is lowered, the angled piece is flat on the ground.
If you don't get the initial angle (mounting) right, it will either have a tendency to dig in as you mention, or ride up over what you are trying to push.
If I do anything, it would probably be to raise the angled piece slightly (relative to the ground) and bolt a strip of UHMW (Ultra High Molecular Weight polyethylene) so the blade won't leave scrape marks on the driveway.
Oh - and I really like your 4-wheel wagon in your avatar. I have an old rusty white 2-wheel wagon that I need to clean up and "John Deereize". Got any up close pics of your wagon?
http://www.mytractorforum.com/showthread.php?t=56681
Thanks for the compliment on the wagon. slkpk
good job red 454, i bought a 316 last summer for 300, was wanting to rebuild and put a paint job on it, the engine has good compression and no leaks, onan engine, the things is ive never painted anything before, any suggestions
If the old paint is still intact (no rust) then all I do is lightly scuff it with sand paper (400 - 600 grit). Then paint.
If there is rust, then I will use sandpaper to knock the rust off, then give it a coat of rustoleum before painting if there is any pitting. If the part is small enough, I will take it into work and sandblast it. Unless it is a tractor that sat outside for years, I wouldn't think there would be much rust (on the tractor). The deck is usually where you see the most rust from years of exposure to wet / dew covered grass.
Can someobody explain why rear blade? Is there advantage? Does it mean that all work have to be done driving backwards? Seems to be inconvenient..
For me it was easier since I had already used it as a rear pusher on my other tractor. It had a snow blower on the front of the old one, and a rear blade was a nice compliment when there was a need to push.
On the JD, it would have required more fabrication to make it a front blade. Plus, at some point I would like to have a front snow blower for this tractor. I will (at some point) then end up with the same setup I had on my Sears tractor.
And yes, it is a little bit of a pain to always have to twist my body around to push backwards. We got about an inch of snow overnight, so I had fun trying out the "new" blade. Worked fine.
However, I realize that with single spool hydraulics, I will have to figure out another way to raise / lower the rear blade when I get a front blower. My old tractor had a manual 3 point hitch, and I modified that to work.
1 - 18 of 18 Posts
