1 - 2 of 2 Posts
I have a 1450 mf and I swore that when I recently bought this machine that rear pto worked. That being said any suggestions why it isn’t working? And would anybody have wiring diagrams of these 1450 mf?
I do not have any wire diagrams but I would suggest you pull the tray under the seat while unit is running and see if pto driveshaft is spinning. If it is your problem is with the belts or engagement system in the rear behind the pulley cover. If it is not spinning your drive belts under dash tower may be in bad shape or not properly tensioned. Hope that helps.
1 - 2 of 2 Posts
