I have a 1970 or 72 Raider 10 (can't remember exact year now) and it is buried in
the garage (can't get to it until spring). But, I think any similar tractor will have the
same cable lift system. You likely can see an illustration on Partstree.com, just plug in
your tractors model number from the build plate under the dash (not "Raider 10").
It should show you a breakdown of the tractor.
Second question: answer is "yes" the plow will fit your Raider 10.
(providing it is a standard A-frame plow. (they made A-frame for horizontal
engine wheel horses)(Vertical engine plow frames were a bit different)
Don't forget you will need the rear "quick attach" hitch for the plow to hang off the rear axle.
