I finally got everything almost perfect on my 332 and noticed a small puddle of oil in the right rear inside wheel rim. I wiped it off not knowing exactly what had caused it but a day later it is back. Can anyone tell me how much effort it is to replace the rear axle seal on this tractor? After looking at the picture on the JD parts catalog I see only one seal per side and it is located on the transmission where the axle goes into it inside of the axle holder. Is this job as hard as it looks? Also, if I overfilled the tranny with fluid would that have anything to do with the drip? I show right at the top of the glass indicator for the fluid level.
