OK new TCV all hooked up (almost). The new lines fit great
and moving the valve back the 7/8" did the trick to get the return line back in place. Not only that w/ a slightly longer piece of hose, 4" is called for but got a piece of 6" from my hydraulic guy and cut to make it fit which ended up being 5". The four might have been enough but first of all I had top slice it to get it off and you can always make them smaller but stretching bigger just don't get it done.
And if you notice, there is now a gap between the line where it comes around the engine. There wasn't before.
And now for those of you that may have noticed the empty fitting on the right side of the TCV... well that's the "almost" that I mentioned. I knew about the leaks in the motor hydro tubes which I remedied, but while looking at the area around the pump and line behind the dash I found this.
After taking it out and flexing the hose it turned into this.
New one ordered and on the way.
MikeC
