1 - 8 of 8 Posts
I was given a Ransomes twin trak model XT2030 R on which the right drive wheel will not operate either forward or reverse but the left side works fine. I don't know much about this type of zero turn mower and I don't know how to go about fixing this problem. Any advice would be helpful. Is the mower even worth fixing? Motor runs good and only has 250 hrs on the meter. I found a parts manual but have not been able to find an operators manual. If anyone has advice on where to find one or can email me one, please let me know.
Just a shot in the dark. Does the right side free-wheel and the left does not? There usually is a lever or mechanism to open any-pass valve on hydro drives to allow a mower to free-wheel roll. Maybe that valve is open on the right side? Just a thought
Yes the right wheel is free wheeling and the left is not, but I do not have an operator manual to tell me where the valve is to re-ingage the right side wheel hydraulics. My parts manual does not show a hydraulics release valve, but there must be one. I just don't have an operator manual to show me where the release valve is.
Those I have seen are near the valve attached to the control levers. Might study the two sides and look for something in a different place on the right versus left. They usually are spring loaded to default to the operations mode and have a catch or mechanism to hold it in the free-wheel position.
Without a manual, winging it like this may work out.
I found two tubes sticking up under the seat. I squeezed them together and locked them together with the attached chain link and discovered both wheels were free-wheeling. When I lowered the chain link and spread the tubes apart, the left wheel engaged but the right one still free-wheels. Since it free-wheels constantly, I suspect the pump might be bad. I don't know if the pump can be repaired or even replaced since it is so old. I may just have to retire the mower to the scrap yard. Does this forum ever have anyone selling a zero turn mower? Thanks for your help.
I agree sounds like the drive has a problem. Could be the manual relief valve, if really lucky. I have owned old Grasshopper mowers for 25 years and never had to repair one of the drives. I know the dealers want to say they can't be repaired but I also know somewhere there is someone to work on anything. Challenge is finding them when you need them. Not sure of that step at the moment.
1 - 8 of 8 Posts
