Mine is low but doesn't drag in the dirt with the 54" blade on. slkpk
forgot that all the time I had was using front blade the lower bracket for driveshaft was hanging down in the dirt... Cleaned the groves out for shafts ,everything connected OK used blower today no problems...
You dont have any options anyway do you? I was thinking the lower pin on the quick attach went through the boxed weldment that holds the driveshaft bearings.
I need to go look but was thinking that was how it worked. If thats the case I need to fabricate a dummy box so I can use the quick attach without installing the drive shaft part.
