1 - 9 of 9 Posts
I just ran across an ad for what is described only as a "14 horsepower K series, idles perfect, no smoke, $175"..
I assume this is a real good price for such a thing, I have not seen it yet, and I am waiting to hear from the guy.
Any variables I need to know about, or if this is a K321S like my existing, will it just fit? Does the spec number matter much? My existing motor is a spec 60275D, and my tractor is a 1975 model.
I am thinking if this fits, at that price, it would be good just for a spare.
Hi,
The price sounds good for for a running K321 14 hp.
I'm assuming you're looking at it for a PK replacement engine?
Obvious items to consider:
*Raised 7" dia step on the output side of the engine(to center bellhousing)
*4- 7/16" treaded bolt hole outside of the 7" dia step to mount the bellhousing.
*1 1/8" dia crankshaft x whatever the pk length is(don't remember)
*Oil Pan configuration-There were at least 3 different types for the different mounting in different tractors
If its from a PK donor then all should be good.
If not then verify that it can work.
If I've left something out then someone else please chime in.
Good luck.
chuckbob
I don't have my Power King near me at the moment...
The guy told me it is a model K321 engine. I asked if it is electric start, and I am waiting for a reply, but can anyone tell me if it is not electric start can I just put my electric start parts on it? He just didn't mention an "S" in the model number. He says his motor is out of a Ford.
Also, thanks for the info chuckbob! I wouldn't be able to measure all that on mine, because it is still in the tractor!
For some reason the fords have an s at the end. I have a k301s in an lgt125. Its the third one of those I've had actually.
1 - 9 of 9 Posts
