Put a new spring on it. You will be glad you did.
The spring has lost it's sprung.
seems to me it won't even work unless i do. This is something you can order at Richard's? Or will some of those springs in the TSC store work?Put a new spring on it. You will be glad you did.
I think that chain and hook is not even supposed to be part of this plow? right?Put a new spring on it. You will be glad you did.
RightI think that chain and hook is not even supposed to be part of this plow? right?
Thanks MarcFound it: Link
Thank you Jepics - the pictures are much appreciated. It looks like the rod i have is not the angle adjusting rod. It is too long to be the latch control rod. It is not real thick - maybe 1/4"?I don't have any really great photos of how the plow pieces mount, but I hope these will help you. The one of the rusty frame (with a pair of Goulds water pumps in background) shows the thinner shiny actuating rod (between the rails) that releases the latch, and the rod that changes the plow angle is on top, tied with rope to the plow pivot bolt.
The photo on the left (with decent paint) has the angle bracket stand mounted on the upper (left) frame member that is unfortunately aligned with and partially blocking the view of the control handle.
Your best bet is to try to find something local. Gravely sub-contracted snow blades out to many companies. There are many different versions, all basically the same, but different. The main area of difference is in the blade end of the frame and swivel area. I have 5 plow frames in the Gravelyyard right now, and at least 4 are different. My newer plow (made for Gravely by Brinley Hardy) is buried and I don't have a picture.seems to me it won't even work unless i do. This is something you can order at Richard's? Or will some of those springs in the TSC store work?
Thanks, it is holding up quite well, the front of the blade will need another coat of paint soon. If I had to do it again (and I might in a couple of years), I would find a way to brighten up the trip springs and I would strip it again and get it powdercoated in gloss black. I did not know until afterwards that the last snowdozers came in black from the factory. I could've saved a ton of money on paint if I'd have done it up in black.That is very very good restoration of a snow blade! I give it a 9.8. I would give it a 9.9 or a 10.0 if the wear strip was painted. The use of all new hardware put it up way up there.
Well done.
Your repaint looks great and for the record, the black B&H blades were satin black.Thanks, it is holding up quite well, the front of the blade will need another coat of paint soon. If I had to do it again (and I might in a couple of years), I would find a way to brighten up the trip springs and I would strip it again and get it powdercoated in gloss black. I did not know until afterwards that the last snowdozers came in black from the factory. I could've saved a ton of money on paint if I'd have done it up in black.
And I always use new fasteners, though I need to buy in bulk like you do.
good info Ron - a bit worrisome to work through my learning curve on this as none of your pics look exactly like what I have. I did not realize there were so many varieties. One big concern is the plow rocks considerably up and down on the bolt where the frame and the pivot assembly plate connect. Perhaps it needs only to be tightened? I think it may be more than that. I have some of my new Kroil working on it now. Looks like I have a fair amount to go to get this functional while ugly - pretty like Marc's is at least off until warm weather.Your best bet is to try to find something local. Gravely sub-contracted snow blades out to many companies. There are many different versions, all basically the same, but different. The main area of difference is in the blade end of the frame and swivel area. I have 5 plow frames in the Gravelyyard right now, and at least 4 are different. My newer plow (made for Gravely by Brinley Hardy) is buried and I don't have a picture.
This is helpful - thanks. I do think the play is excessive however. It is probably caused by a bend in the weldment at the very front of the push frame through which the bolt passes that attaches it to the plow. I have posted some pics.Don't worry about getting the pivot bolt completely tightened down . In order to work the blade needs a bit of looseness or slop to allow it to follow the pavement and be able to use the angle function, get it too tight and you will have a difficult time trying to angle the blade and it will leave more snow on the pavement as it can't move freely. Yes there can be too much slop when the pivot bolt is badly worn in diameter or the holes are egged out.
