I am making an offer on a GT3235 that comes with a blower (and wheel weights & chains) and seems to be in very good condition – no obvious signs of abuse or lack of maintenance. I have driven the tractor and checked out the controls and everything seems fine, but there are a number of things I have questions about:
1. Is there is anything to look for regarding the hydraulics? It has the blower mounted and it raises and lowers quickly.
2. It has a solid strut installed where I believe the angling cylinder would go. Was that a separate kit? Can they still be had?
3. What about the diff-lock? The pedal engages and I don’t hear any noises, should I look for anything else?
4. The seller says the deck (48” ground contact) is difficult to get off without raising the front end because the angle drive gearbox contacts the lift linkage. How big an issue is that?
5. The steering is sharp, but the wheel is off center. To straighten, is that a simple R&R like most Cubs?
Thanks for whatever advice you guys can offer.
