question on rim size
1126 Views 4 Replies 4 Participants Last post by  Boyd
I was wondering if a rim from a 1997 ford f150
would fit on a 2001 f150 Thanks for any help
ED CASO
My guess would be yes as far as bolt pattern goes. Assuming both are either 2wd or 4wd it should fit. Alot of times there is a variance in backspacing between 2 and 4wd so if one truck is 2 wheel and the other is 4 it may not work.
97 and 01 were pretty much the same truck. Should fit as long as the trucks are the same drive setup.[ie 2wd, vs 4wd]
Another thing to consider is if it will clear the calipers as brakes have been getting larger in the last 15-20 years.
