Will a 22hp v twin briggs fit on a 1994 broodmore that has a 16hp briggs vanguard in it now.I'm not sure if the pulley from the 16 will fit on the 22 or if the engine mounting holes will line up,or throttle linkage.I dont have the 22hp yet I told the guy I have to check fit first.Any help would be great.:thanku:
I'm trying to do that now on my Broodmor...
Best to get the model/series numbers and compare. The 16hp Vanguard probably had a 1" diameter by 3-5/32" length straight shaft with a 1/4" keyway and a tapped end for electric PTO. Not sure if the manual blade engaugement used a different shaft length. There are some places on-line that have mounting dimensions / diagrams.
Don't forget about:
If you have electric PTO - need to make sure the new motor has a hi-amp alternator. Does the new engine have a fuel pump? Will the exhaust swap over?
Good luck - I haven't found a replacement for mine yet, just been investigating.....
