Hard to say with just a little information. An acre to mow, whether slopes are present, or if any other duties the "old girl" was doing such as snow plowing, garden work, or yard cart duties. Those other duties are not served well, if at all by a ZT mower. I love my CC ZT2 but it is a bit lightly constructed and used ONLY for mowing the bulk of my 4 acres of hilly land. It uses a Kawasaki engine and Hydrogear ZT2800 transmissions both with oil filters. Those and oils are changed every season. However, I am pushing this higher residential mower hard in my conditions so the engine and trans' maintenance are important to get as many hard hours out of this as I can. It runs about 100 hard hours per cutting season depending on rain and growth.
As far as ZT mowers, I have to say I would prefer a pressure lube system for sure. Constant pressure, and particularly, filtering is always a plus.
For longevity, maybe consider a used machine closer to commercial grade than residential. If it has been maintained, you'd be better off that way.
Again, these are only opinions. Wish you good luck in your search for a replacement.
