question for those that own a FEL.
1736 Views 6 Replies 4 Participants Last post by  Bozang1
I have recently picked up a B5100 tractor. I know a FEL was available on these tractors and have downloaded some pics off the net, but none really show what I need to see. I'm trying to figure out how the sub-frame was made and how it mounted. If someone can give me a link to a site that has a manual with this info, or post some pics of a comparable Kubota with some really good shots of the sub-frame, that would be great. Thanks.
1 - 7 of 7 Posts
Do you know the loader model number? If so, you can go here and check if someone posted the manual online. It's listed by loader model, so I don't know if the one for the 5100 is listed. Someone else may have other suggestions if this doesn't work. Good luck.
www.kubotabooks.com
Chris, Great website!
Back to the loader I have a B6100 and it has the B219 loader. MAy be what a 5100 would have?
Also, just remembered, www.tractorsmart.com provides parts manuals for free via e-mail - takes about a day to get it - if it's not listed on the kubotabooks site. You can find your tractor model in the drop down list, then add the FEL model (if you know it) in the attachment box. Maybe they have that manual for you.
Good stuff - that model is listed at kubotabooks. Hopefully for the OP, that's the right loader model.
Quick search on Google images, 5100 looks like a 2 wheel drive version of
6100. B219 should work.
The 6100 is longer. I have a 5100 and mounted a FEL from a 6100 and had to "make it work" (cutting some holes, welding some pieces, and deleting aft supports that attach to rear axle/pumpkin. You can do it if you have the resources and know how. My loader says AG TECH on it and thats all I know. They used to make stuff like this back then...
1 - 7 of 7 Posts
