1 - 3 of 3 Posts
Was able to mow again last night and something I noticed was the lever to engage the mower deck doesn't hook all the way into the notch it is suppose to when you engage it. Anyone else notice this with theirs? It's almost like the lever is suppose to be a little bent to fit in there right.
Discussion Starter · #2 ·
Took a picture tonight. I have it in the engaged position and you can see how it should go further into the slot. If I go over bumpy enough terrain it will bounce out of position and disengage. Think I am going to have to have the dealer take a look at it.
Look under the fender where the lever makes a 90 degree turn, the are two bolts there where you may be able to adjust the angle of the lever so it will drop into the slot.
1 - 3 of 3 Posts
