I replaced the brake shaft on the transaxle and a couple of questions before I put it back in.
I removed the axle horns, I opened the transaxle and replaced the shaft and put it back together. I left everything the same way, everything looked ok.
The pulley on the pump is moving freely, I can also spin the shaft by spinning the brake disk, is this normal? anything I can do to make sure it is ok to go back on? Other than adding the oil (2 quarts of Castrol 20/50) put it back on the tractor and see if it engages.
Thank you
Thank you
